Mesh error
Posted: Thu Oct 07, 2021 1:16 pm
by AntoMarinelli
I have an error in the mesh but I don't manage to find the problem.
I attached the file.
Thanks in advance
Antonella
Re: Mesh error
Posted: Fri Oct 08, 2021 7:40 am
by LuisB
Hi AntoMarinelli!
I was checking your model, and that issue comes from the improper assignment of the element property to the geometry. To fix it:
1. Unassign the element property (Shell) to all the geometry
2. Select just the faces of your model. To do this, you can use the Work tree > Geometries > Merges > Faces (Select)
3. Assign the shell element property to the selected geometry
After these steps, STKO will give you a message regarding the Selection Set "Midspan" which is empty, add the point to it and you are good to go!
