Applying Earthquake Motion to each node at model bottom separately
Posted: Mon Aug 02, 2021 5:12 am
Dear support member,
I have a quick question about the boundary condition applying earthquake time series to model bottom for modeling seismic geotechnical structures (i.g., square/rectangle sites, slope, retaining structures or shallow foundation etc.)
I believe that, in STKO, we can put earthquake time series (acceleration or velocity) to each node at model bottom individually with an time interval (e.g., sampling rate of the record).
As shown in the attached figure,
I want to give the entire time series to the first node at time = 0 sec, and then
do it to the second node at time = dt sec (e.g., 0.01sec which stands for sampling rate of time series), and then
do it to the third node at time = 2xdt sec so on till by the last node on the right side of model bottom.
(In other words, the ground shaking at the first node starts at t = 0 sec and
the ground shaking at the second node starts at t = 0.01 sec and
the ground shaking at the third node starts at t = 0.02 sec so on)
This means (you may recognize my purpose) that
I want to simulate the inclined wave propagation within OpenSees.
(This may be referred as 'moving node' for entering earthquake record).
This can be done by python-API (PyMpc), right?
I would like to have some comments or tips for achieving this task from you.
Youngkyu
Youngkyu
