how to use the equalDOF
Posted: Wed Jun 09, 2021 4:03 pm
by chry
Hi, I am having a problem using STKO. I want to know how equalDOF command in condition selects entities. I can't select any entities after adding equalDOF command, but fix command can select nodes.
Re: how to use the equalDOF
Posted: Thu Jun 10, 2021 8:10 am
by marafini.f
Dear chry,
to assign an equalDOF condition you need to select an interaction, not just a specific node or nodes. The equalDOF constructs a multi-point constraints between nodes, in order to do that you need to define an interaction between the nodes you want to constrain to some other which are retaining them.
Once you have an interaction you will be able to select it from the condition editor when creating the equalDOF condition.
Enjoy your modelling
Posted: Thu Jun 10, 2021 3:21 pm
by chry
Thank you for your help. I'll try it. Thanks again!
Posted: Thu Jun 10, 2021 5:35 pm
by marafini.f
You are welcome!
