Help in deciding mesh and step size
Posted: Wed Apr 14, 2021 4:46 pm
Dear Sir/Madam
I have been modeling a masonry wall with a dimension of 0.99 m x 0.99 m x 0.09m with mortar thickness of 10 mm. Brick size 190 x 190 x 90 mm3. The objective was to obtain lateral force vs displacement curve. Keeping every other parameters, I observed that the peak strength depended on the mesh size, as well as the "number of "increment" or the "load step-size" in the analysis option. Following are the specific questions treating the mesh size and the number of increment independently:
1. For example if we consider only the mesh size option (structured+quad), I got the following peak strength: By Uniform Division--> 114 kN, By Uniform Size (30)-->80 kN. You can see the 34 kN difference!
2. On the other hand if we consider the "number of increment (N)" in the analysis option for displacement controlled analysis up to 1mm, keeping the mesh size same, I got the following peak strength: N= 50, dT=1/50=0.05-->108 kN; N=100, dT=1/100=0.01-->97 kN; N=200, dT=1/200=0.005-->92 kN
Can you please guide me on how to choose the appropriate mesh size and the number of increment for analysis? Any guidance on it is greatly appreciated.
