How to add work tree and command bar in pre-processor window
Posted: Mon Aug 17, 2020 5:34 pm
by Asad005
The work tree and command bar is missing from the Preprocessor window.
It happened when I switched to the post-processor window and I deleted the work tree & command line of the Preprocessor window appeared in the Postprocessor window.
The screenshot is attached here.
Re: How to add work tree and command bar in pre-processor window
Posted: Tue Aug 18, 2020 8:32 am
by HC2020
Hi Asad,
In order to get your worktree and command line (I assume by command line, you mean terminal window)back, all you need to do is right click in a blank part of the main toolbar. This will open an editor panel. In that panel simply click to select the features you want to view.
I hope this helps!
Screenshot (22).png (307.28 KiB) Viewed 2903 times
Posted: Tue Aug 18, 2020 9:32 am
by Asad005
More than thanks :)
