connect shell wall and truss rod
Posted: Tue Jun 30, 2020 10:05 am
I am modelling a tie rod on top of a masonry wall, modelled with shell elements in 2D. The rod is instead an elastic truss.
I would like to connect the rod just at the extremities of the wall, but if a merge the shells and the truss, it gets connected at each vertex of the shells.
I then tried with an interaction (Equal DOF) between each extremity of the rod and the corresponding extremity of the wall. I can see in the tcl file that this constraint is actually written, but not even the gravity analysis runs (the error is attached).
What is the correct way of modelling this interaction?
Thanks
Chiara
Thanks
Chiara
