Force Response History of Elastic Sections
vokumus
Post by vokumus » Sun May 10, 2020 2:06 pm
Hi;
Is there any way to extract time-force history data from elastic elements? There are only nodes, Gauss points and fiber options in extract data menu.
update: solved this adding a custom recorder command. If there is a more convenient way please share.
Thanks.
Vefa OKUMUS
MSc. Structural Engineer
PhD candidate.
Software Developer.
Istanbul - Turkey
Re: Force Response History of Elastic Sections
Post by STKO Team » Mon May 11, 2020 1:57 pm
time history chart refers to a point of the structure. In STKO it's possible to extract it from nodes, Gauss points and fiber.
Unfortunately results on element-nodes (such as force in elastic beam) are not supported in ExractChartData. We will add it soon. In the meanwhile you can do it, using a general dispBeamElement (so with gauss points) where each section is an Elastic section. In this case you can extract section.force at the gauss points near the beam ends
vokumus
Post by vokumus » Mon May 11, 2020 3:24 pm
That's a great way to solve it. It was hard to work with custom recorder. Thanks.
Vefa OKUMUS
PhD candidate.
Software Developer.
Istanbul - Turkey
StavrosP
Post by StavrosP » Wed Dec 04, 2024 4:42 pm
on a similar topic, using STKO v4.0.0, I would like to extract the local (shear) force of a beam element. I am using "Force-Based beam-column" elements, with Standard Integration Types (Lobatto, 5GPs), with Elastic section. While I can visualise the local shear, I cannot extract the data in a tabular form via the postprocessor. Can you please let me know if there is workaround?
Stavros
STKO - local shear force.jpg (135.4 KiB) Viewed 2576 times
Post by STKO Team » Mon Dec 09, 2024 9:58 am
Check this option to make the force-beam-column shear-deformable:
Record section.force, and on gauss points you will be able to see and extract the transverse shear.
Note: When the beam is shear-deformable (Timoshenko), shear deformation and force are available at the section level.
When it's not shear-deformable ( Bernoully ), you will only see the shear forces at the element level (force or localForce) due to equilibrium
