basement interaction with soil
Re: basement interaction with soil
Post by STKO Team » Fri Feb 11, 2022 9:59 am
What is the difference between Krylove-Newton and Newton with Line Search?
There is a lot to say about this... You can find more details in the literature, however, the Krylov-Newton can be better when you have materials with strain softening. While I found the newton line search better for contact problems.
Does it make sense for me to change this?
Yes, in fact you solved the problem with this.
Is there any other way to converge the model?
Now it's fine, from the image I can see that your analysis finished successfully.
Probably you will have other issues if you will start using nonlinear material for soils.
But nonlinear analyses are like this... You have to try different options, there is no unique rule...
