Probably the properties you used for the springs were not equivalent to the properties you assigned to the Soil model. I suggest you double-check the properties of your soil. Start with an elastic material first, because, with your springs, the response was different already in the linear stage.Maybe you are right and in this case, the soil is not affecting the behaviour.. but if I model the springs, it does...You can see that in the plot attached. That's why I wanted to check what happens if I add another type of interaction...
Once you check them, you can move to a nonlinear model. Another note: you used the PressureIndependentMultiYiled, but since it is pressure independent, it means it uses a Von-mises-like criterion. I think you should use the PressureDependent material, which instead uses a Drucker-Prager-like criterion.
It happened for 2 reasons:Yes, I tried that. I added ZL3dcontact in the structure. However, there is a convergence problem. Two foundations seem to be collapsing in the first steps of the analysis (see image).
- your beamToSolidCoupling condition is using only the 4 corners as slave nodes, while you should use the whole top face as slave.
- You used EDOFs for the foundation sides, which will restrain the foundation rigid body rotation.
