Page 5 of 6
Re: How to consider the rotational mass in linear elastic static analysis?
Posted: Mon Nov 22, 2021 12:07 pm
by pucho
Thank you Francesca!
Posted: Thu Nov 25, 2021 9:47 am
by marafini.f
Hi pucho, sorry for the late reply.
There is actually no model in your zip folder, just a .py file
Do you want to share your .scd file?
Posted: Thu Nov 25, 2021 2:15 pm
by pucho
Sorry, Francesca, here is the file
Posted: Fri Nov 26, 2021 2:07 pm
by marafini.f
I had no problem running your model pucho. What's wrong about it?
Posted: Fri Nov 26, 2021 9:16 pm
by pucho
That is the model with simple interactions with no problem. The previous model I sent you, has the convergence problem.
Posted: Mon Nov 29, 2021 8:43 am
by marafini.f
Ah ok,
I thought you had done some modifications following these suggestions.
so if you erase your column and run the analysis no error occurs, so I think there is something wrong with how you defined them. I would suggest you draw your geometry separately and then move it in place after you created the interaction. Moreover, you need to check for instability, are you sure you gave enough DOFs property to avoid geometric singularities?
You can try assigning properties to the zeroLength first to all DOFs, than scaling down one by one and check when it starts to fail.
Let me know how your attempts goes.
Posted: Wed Dec 01, 2021 12:22 pm
by pucho
Thank you, Francesca, I will proceed as you suggest and let you know.
Best regards,
Hernan
Posted: Mon Dec 06, 2021 8:38 am
by marafini.f
You are welcome,
Enjoy your modelling
Posted: Mon Dec 06, 2021 1:51 pm
by pucho
Dear Francesca,
I have another question, I am using the OrthotropicMaterial mapper and I what to know if the requested properties are in Local or Global coordinates.
Thank you very much for your answer,
Hernan
Posted: Tue Dec 07, 2021 9:22 am
by marafini.f
Hi Hernan,
so the Orthotropic material behaves differently if you are applying it on a 3D element or on a 2D element.
Solids handle materials in the global coordinates, while shells in local coordinates. In the instance of shells, the X-axis corresponds to the first column of the Jacobian computer in the center.
Let me know if you need anything else.
