Installation errors
Re: Installation errors
It looks like you correctly activated your license in our database the 27th of February. For some reason it didn't work on your PC. Try now
Yes it's working now, thank you!
[email protected]
Hi, I have the same problem (appears the same error message ) and tried to install the software again, but did not succeed. Hence, if necessary, the code in the System Info is 2B4AE8D8EDA8BE80B89AE464A438214058A23BC083D067B0.
Thanks in advance
Thanks in advance
[email protected]
Now, everything is right. Thanks a lot
"networking error(5)"
activation key..
Code:
2C4AF4E4E8A2945823201CF8EB983F70AAA285B03FA439B0
activation key..
Code:
Hi Mesay,
Try now! The problem should be solved.
RiccardoDi%20Blasio
Ciao, anche io ho questo problema.
Grazie
Grazie
- Immagine1.png (8.04 KiB) Viewed 5515 times
- Immagine.png (6.68 KiB) Viewed 5515 times
