Re: RE; Force displacement behaviour and extraction
Posted: Tue Mar 17, 2026 8:49 am
I think the best way for you is to examine the model in detail.
First look at the location of plastic deformations and check they are in the same area as in plaxis.
Also compare the displacement/rotation at bottom and top of the pile.
In this way you can check wether the boundary conditions are correct and the model is displacing the same way.
Then try to inspect the stress-strain behavior at the Gauss points undergoing the maximum plastic deformation, and try to see if there are any visible differences (to understand if the difference comes from the material response)
