How to simulate soil below water level
Re: How to simulate soil below water level
Post by STKO Team » Mon May 20, 2024 8:42 am
Ok. Did you fix it now?
BuuNguyen
Contact:
Post by BuuNguyen » Tue May 21, 2024 7:40 am
Yes, You can see the results in the attached figures.
1/ Fixed PWP at the top boundary on the left side: not correct PWP results, but run well in EQ analysis
2/ Not Fixed PWP at the top boundary on the left side: correct PWP results, but not converged in EQ analysis
Model file was also attached. Do you have any suggestion?
Thank you,
Buu
model file.rar
(457.38 KiB) Downloaded 188 times
Fix PWP.png (394.59 KiB) Viewed 1218 times
Not fixed PWP.png (440.53 KiB) Viewed 1218 times
Post by STKO Team » Wed May 22, 2024 10:23 am
You have to figure out what is going on on that side.
It seems that the stress induced by the elastic analysis is too high and as soon as you switch to plastic analysis the stress is way too far from the yield surface.
Then this part starts to experience huge acceleration and plastic deformation
