Page 2 of 2
Re: pushover analysis
Posted: Thu Apr 28, 2022 12:49 am
by akshaysomkuwar123
Thank you very much for the help.
I was wondering doesn't the pushover still continue even if 3 members are failing and show decreasing branch after peak, to observe progressive collapse and how it is spreading over the structure.
Posted: Thu Apr 28, 2022 8:09 am
If the snap-back is very severe the displacement control will fail
Posted: Thu Apr 28, 2022 11:38 am
for non linear THA the model is showing larger displacement.
How can this issue be solved?
Posted: Thu Apr 28, 2022 3:50 pm
What do you mean?
Posted: Fri Apr 29, 2022 12:27 am
I conducted nonlinear time history analysis on the dome and the observed peak displacement magnitude is higher than the pushover. I am attaching a plot of peak displacement observed for the dome. So if the nonlinear THA response is larger, I was wondering if there is something wrong with the way pushover analysis is happening.
How can the issue of pushover be solved?
Does the issue is related to the loading protocol I used in the pushover which is causing numerical instability?
Posted: Fri Apr 29, 2022 8:33 am
Well keep in mind that you cannot do a perfect comparison! they are different analyses and the load on the structure is applied in different ways.
In the pushover you are monotonically increasing a pre-defined load pattern, until some member become unstable. In a dyanmic analysis you have a base acceleration which puts intertia forces on the structure in a completely different way, both in terms of spatial distribution and temporal distribution.
But the order of magnitude is the same: 33 mm for pushover and between 40 and 50 mm for transient... is not that different
Posted: Sun May 01, 2022 11:56 pm
I get what you are saying. With pushover, I wanted to check how progressive collapse of the dome occurs.
Posted: Mon May 02, 2022 7:55 am
