E_SFI_MVLEM_3D
E_SFI_MVLEM_3D
It appears that E_SFI_MVLEM_3D element is not implemented in latest STKO, but it has been available in OpenSees for some time.
https://opensees.github.io/OpenSeesDocu ... EM_3D.html
Is there a way to add it without waiting for new STKO version? I remember you had some Python scripts that can be easily added to STKO installation directory.
Please let me know.
Thanks
Please let me know.
Thanks
Re: E_SFI_MVLEM_3D
We will look at it tomorrow,
it should be super easy as the input seems the same as its parent element
Re: E_SFI_MVLEM_3D
Yes it should. Thank you! Looking forward to hearing from you.
Re: E_SFI_MVLEM_3D
Hello, I just wanted to follow up on this. Thank you.
Re: E_SFI_MVLEM_3D
Hello, I just wanted to follow up on this again. Thank you.
Re: E_SFI_MVLEM_3D
Done, we will add it in the next version of STKO.
In the meantime:
In the meantime:
- Add this python file in C:\Program Files\STKO\external_solvers\opensees\element_properties\beam_column_elements
- Put this json file in C:\Program Files\STKO\odb_rules replacing the old one
- Finally for a proper visualization you need these changes in the MPCORecorder.cpp file in OpenSees (we will do a PR soon):
Re: E_SFI_MVLEM_3D
Thank you very much! Please let me know when E_SFI_MVLEM_3D model visualization is implemented in OpenSees so I can start using it.
Thank you,
Thank you,
Re: E_SFI_MVLEM_3D
I was just wondering if you have submitted the abovementioned PR and if I can use the E_SFI_MVLEM_3D, including visualization, in STKO.
Please let me know.
Thanks
Please let me know.
Thanks
Re: E_SFI_MVLEM_3D
Not yet, hopefully I'll do during the next week.
In the meantime you can try to put those 2 modified lines in the mpco recorder in your local opensees source and compile it
BrownTrout_NZ
Re: E_SFI_MVLEM_3D
Hi STKO team
Just wondering how far away is the new version of STKO release with E-SFI included ?
Alternatively can someone please compile the c++ file and unload a link ? I am not competent with compiling.
Thanks in advance.
Thanks in advance.
