local variable 'perm' referenced before assignment
Dear STKO team, can you tell me how to deal with the problem in the following pictures.
- loacl variable 'perm' referenced before assignment.png (31.14 KiB) Viewed 3329 times
Re: local variable 'perm' referenced before assignment
This means you assigned a 3-node shell element (ShellDKGT) to a mesh with a different number of nodes (not a triangle)
[email protected]
I'm getting the same error, and I'm sure I'm using 4-node faces. Could you help me to solve it, please?
Thanks!
Franco
Thanks!
Franco
- Shell elements Issue.png (151.55 KiB) Viewed 556 times
Hi, I used the same element and section as you did, but I didn't receieve such error. Input files were correctly written as you can see in the attached picture. It may be due to other reasons, please check the last sentence of the error message and the python files associated with the error.
- Screenshot 2024-11-07 063021.png (116.04 KiB) Viewed 544 times
