Hello
I'm running a static analysis of a RC frame made of fiber beam elements. When I start the analysis it gives me these errors
MPCO recorder - Written by ASDEA Software Technology: M.Petracca, G.Camata
ASDEA Software Technology: https://asdeasoft.net
STKO (Scientific ToolKit for OpenSees): https://asdeasoft.net/stko/
If you use this tool, please cite us:
Petracca, M., Candeloro, F., & Camata, G. (2017). "STKO user manual". ASDEA Software Technology, Pescara Italy.
after: 2000 iterations current Norm: 5.73752e+17 (max: 0.0001, Norm deltaR: 2.99269e+09)
AcceleratedNewton::solveCurrentStep() -The ConvergenceTest object failed in test()
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.1
Reducing increment factor due to non convergence. Factor = 0.5
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.05
Reducing increment factor due to non convergence. Factor = 0.25
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.025
Reducing increment factor due to non convergence. Factor = 0.125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.0125
Reducing increment factor due to non convergence. Factor = 0.0625
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.00625
Reducing increment factor due to non convergence. Factor = 0.03125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.003125
Reducing increment factor due to non convergence. Factor = 0.015625
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.0015625
Reducing increment factor due to non convergence. Factor = 0.0078125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.00078125
Reducing increment factor due to non convergence. Factor = 0.00390625
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.000390625
Reducing increment factor due to non convergence. Factor = 0.001953125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.000195313
Reducing increment factor due to non convergence. Factor = 0.0009765625
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 9.76563e-05
Reducing increment factor due to non convergence. Factor = 0.00048828125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 4.88281e-05
Reducing increment factor due to non convergence. Factor = 0.000244140625
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 2.44141e-05
Reducing increment factor due to non convergence. Factor = 0.0001220703125
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 1.2207e-05
Reducing increment factor due to non convergence. Factor = 6.103515625e-5
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 6.10352e-06
Reducing increment factor due to non convergence. Factor = 3.0517578125e-5
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 3.05176e-06
Reducing increment factor due to non convergence. Factor = 1.52587890625e-5
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 1.52588e-06
Reducing increment factor due to non convergence. Factor = 7.62939453125e-6
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 7.62939e-07
Reducing increment factor due to non convergence. Factor = 3.814697265625e-6
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 3.8147e-07
Reducing increment factor due to non convergence. Factor = 1.9073486328125e-6
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 1.90735e-07
Reducing increment factor due to non convergence. Factor = 9.5367431640625e-7
ERROR: current factor is less then the minimum allowed (9.5367431640625e-7 < 1e-06)
Giving up
while executing
("while" body line 87)
invoked from within
"while 1 {
# check end of analysis
if {[expr abs($STKO_VAR_time)] >= [expr abs($total_duration)]} {
if {$STKO_VAR_process_id == 0} {
puts "Tar..."
(file "analysis_steps.tcl" line 57)
invoked from within
"source analysis_steps.tcl"
(file ".\main.tcl" line 81)
How can I solve it? Thank you
Static analysis of a RC frame model
giulio.zanellato
Re: Static analysis of a RC frame model
Hi, The geometry is not merged! So, singularity arises due to the split geometry, not being connected togther. Try selecting all beams and columns and merge them. Mesh the geometry again and run the analysis. I found that the number increments in horizontal analysis is too less, only 10! Please increase it to 100 atleast. Also, why do you apply the gravity load using constant time series. There is a chance for some level of nonlinearity to set in the model, so try to apply the gravity load by following linear time series.
giulio.zanellato
ok now it works. Thank you very much
