Add bodyforce
Add bodyforce
I noticed various body force settings in multiple places within STKO, such as the density of some materials (e.g., PressureDependentMultiYield), the body force in the elements (e.g., quad), and the mass or load in Conditions.
Could you please explain the differences between these settings? Do they impact calculations?
Re: Add bodyforce
Density and mass are associated with dynamics analysis, they will not add any static structural loads, as the other (body force and load) do. If you specify density of the material, the equivalent mass at nodes for the elements are internally calculated and assigned. Otherwise, you should manually calculate the mass and assign at the nodes. So, density option for material adds a layer of sophistication.
Re: Add bodyforce
It seems that the body force within the element also contributes to this sophistication.kesavapraba wrote: ↑Mon Jun 03, 2024 7:21 amIf you specify density of the material, the equivalent mass at nodes for the elements are internally calculated and assigned. Otherwise, you should manually calculate the mass and assign at the nodes. So, density option for material adds a layer of sophistication.
Re: Add bodyforce
Yes some elements have the body force as input.
But not all of them, that's why in STKO we developed utilities such as VoulumeForce, FaceForce, EdgeForce... to provide for distributed forces where not available in OpenSees
Re: Add bodyforce
So, for face force, should I consider the thickness of the quad element?
Re: Add bodyforce
A FaceForce is a pressure F/L^2, so yes, you can compute it as self-weight (F/L^3) times the thickness
Re: Add bodyforce
Alright, I think Opensees will time the thickness automatically.
Thanks for your reply!
Re: Add bodyforce
You need to multiply the self-weight (either in N/m3 or kN/m3) with the corresponding thickness and apply it as face force (STKO automation) along the inplane direction of the quad element.
Re: Add bodyforce
Best wishes!
Best wishes!
