nDmaterials - ASDEASoftware / PlugIn
[email protected]
Post by [email protected] » Fri May 17, 2024 12:06 pm
I am trying to apply the nDMaterial (ASDEASoftware / PlugIn) to simulate the masonry wall. Now, I am using the free unlimited 30-day trial of STKO, but when I perform the analysis, the following WARNING always occurs. Could you help me to fix it? Look forward for you reply.
Best regards!
Tao
WARNING could not create nDMaterial: plugin
Re: nDmaterials - ASDEASoftware / PlugIn
Post by STKO Team » Fri May 17, 2024 2:06 pm
It's because you are using the official OpenSees version.
In that version, the maintainer didn't want to add our plugin. So if you want the DamageTC3D, you must use the unofficial version distributed by Prof. Tarque here: https://www.pucp.edu.pe/profesor/sabino ... ducciones/,
otherwise you can use the ASDConcrete3D which instead is in the official version of OpenSees
[email protected]
Post by [email protected] » Sat May 18, 2024 12:45 pm
Thank you very much! I have fixed the problem!
Post by STKO Team » Mon May 20, 2024 8:42 am
A.Manan
Post by A.Manan » Sat Dec 20, 2025 8:08 pm
hi!
can you tell me how did you fixed it?
thanks
Post by STKO Team » Thu Jan 22, 2026 9:00 am
Download the un-official version compiled by prof. Tarque
https://www.researchgate.net/publicatio ... ltext=true
