I built a 5-story RC frame using STKO and performed a time history analysis on it. I input the seismic acceleration in three directions using UniformExcitation. Because the result of each node is the relative acceleration to the ground, I analyzed the absolute acceleration of the top and first floor top nodes in the excel file, but found that the acceleration in the x direction was almost not amplified (for example, the input peak acceleration in the x direction is 6000 mm/s2, the peak absolute acceleration of the top node is about 7000mm/s2, with almost no amplification), which is contrary to common sense in structural dynamics. I think the calculation results of STKO maybe incorrect and I am not sure whether the results in the z direction are correct.
Could you please help me check if there are any problems in the model or settings, which is related to whether my project can continue.
Model and excel file are in the attachment.
Best Regards
