Unit system of ElastomericX element
Edmond2000
Post by Edmond2000 » Sat Mar 02, 2024 11:09 am
In the webinar about seismic isolation, the tutorial uses the unit system of m-kg-N. If the unit system of mm-t-N is used to input parameters in the ElastomericX element, can OpenSEES calculate the correct result?
All the best
Re: Unit system of ElastomericX element
Post by kesavapraba » Mon Mar 04, 2024 12:57 pm
Hi, OpenSees follows a consistent unit system, which means you can use any unit system of your choice. However, it's important to note that all dimensions and material properties should be defined according to the chosen unit system. The results obtained will also be in the same unit system. As per the ElastomericX element's Wikipedia page (link below), both SI and Imperial unit systems can be used. However, please pay attention to the default values of the heating parameters, which are defined in SI units. If you want to use any other unit system, you will need to convert the values accordingly.
https://opensees.berkeley.edu/wiki/inde ... astomericX
Edmond2000
Post by Edmond2000 » Mon Mar 04, 2024 1:06 pm
Thanks for your reply. I have built models using different unit systems and found the results to be equivalent.
Have a nice day.
Post by kesavapraba » Mon Mar 04, 2024 1:08 pm
You are welcome. Happy to note that.
