Post
by kesavapraba » Fri Feb 16, 2024 6:58 am
Hi, Sorry I tried my best to figure out the issues in your geometry. I could achieve meshing the top portion only. The geometry of the model is complex, particularly in the lower portion of the model, there can be some short edges that creates the issue. You can recreate the lower portion, add every small geometry in a step-by-step manner and simultaneously check for successful meshing. In this way you can come to know where the issue is.
- meshing.jpg (123.2 KiB) Viewed 4204 times
