local variable 'perm' referenced before assignment
xgx
Post by xgx » Thu Oct 19, 2023 9:32 am
Dear STKO team, can you tell me how to deal with the problem in the following pictures.
loacl variable 'perm' referenced before assignment.png (31.14 KiB) Viewed 3331 times
Re: local variable 'perm' referenced before assignment
Post by STKO Team » Mon Oct 23, 2023 8:20 am
This means you assigned a 3-node shell element (ShellDKGT) to a mesh with a different number of nodes (not a triangle)
xgx
Post by xgx » Sat Oct 28, 2023 1:07 pm
Thank you very much, I have fixed the problem.
Post by STKO Team » Mon Oct 30, 2023 9:08 am
[email protected]
Post by [email protected] » Wed Nov 06, 2024 8:21 pm
I'm getting the same error, and I'm sure I'm using 4-node faces. Could you help me to solve it, please?
Thanks!
Franco
Shell elements Issue.png (151.55 KiB) Viewed 558 times
Post by kesavapraba » Thu Nov 07, 2024 5:32 am
Hi, I used the same element and section as you did, but I didn't receieve such error. Input files were correctly written as you can see in the attached picture. It may be due to other reasons, please check the last sentence of the error message and the python files associated with the error.
Screenshot 2024-11-07 063021.png (116.04 KiB) Viewed 546 times
