Error:physical property must be sections and not special_puepose
[email protected]
My model has an error as shown in the image, but I don't know exactly where this error is, because I still have an identical model that works. It would be great if you could check it out for me, thank you.
![Image]()
- b81b93560e475f0b85ef28844a9c35d.png (18.95 KiB) Viewed 4461 times
- 7-3.rar
- (159.96 KiB) Downloaded 305 times
Re: Error:physical property must be sections and not special_puepose
It's because you are using a DispBeamColumInt, try the dispbeamcolumn or forcebeamcolumn.
[email protected]
Dear STKO Steam:
Thank you very much for your previous help, but I fixed it and got a new error, if you have time I would like to get your help again.
- 7-3.rar
- (168.52 KiB) Downloaded 277 times
- d52f0883f4e3ef12cf83af97ff44274.png (23.57 KiB) Viewed 4436 times
ValentinaSB
Can you please attach the model where you have this error? I tried to change the element properties in the model you attached before, and it works for me. (you also need to add a node to your selection set that you use for displacement control)
Valentina
Valentina
[email protected]
Thank you very much for your reply, this is my model, look forward to your help, it is important to me.
- 7-8.rar
- (168.44 KiB) Downloaded 284 times
It's because in your monitor you did not choose any selection set
[email protected]
Thank you very much for helping me find this error, but after I fixed this error, I found that it still does not work, I don't know what the error message in the figure means.
- b32918bfb296a768791e325506b424d.png (67.99 KiB) Viewed 4301 times
It seems you set up your analysis for parallel computing with OpenSeesMP ( I can see it from the ParallelRCM numberer), but you lanched the sequential opensees that does not have that option.
Just use OpenSeesMP
Just use OpenSeesMP
