Infill wall material is not running (error using beamwithhinges)
ragopesa
Post by ragopesa » Thu Jun 08, 2023 12:34 am
I hope you are doing great.
I'm using the infill material that you showed in your previous webinars. Despite I followed the steps, the terminal showed me the following message:
"element beamWithHinges 17 10 3 7 [expr 5656.85424949238*0.1] 19 [expr 5656.85424949238*0.05] 300.0 1386.4017265312752 167375.06803104692 0.001 [exp..."
I also run the model provided in your website, and actually it has the same error. Please, could you giveme guidance on this topic?
I also attached a simple model (one frame) using gravity analysis. I only use this for testing.
All the best,
Salvador
3regular_infill.7z
(94.37 KiB) Downloaded 257 times
Re: Infill wall material is not running (error using beamwithhinges)
Post by STKO Team » Mon Jun 19, 2023 2:25 pm
it looks like in the current version of OpenSees the beamWithHinges cannot be used anymore (it was used internally by the infill wall element).
It's not a problem, since the beamWithHinges is actually a force-beam-element with a special integration scheme. We just updated the Python file to use the new format.
Unzip this:
MasonryInfillWallElement.zip
(7.27 KiB) Downloaded 281 times
and place it in C:\Program Files\STKO\external_solvers\opensees\element_properties\special_purpose, replacing the existing one. It will be available for all users in the next STKO version.
Let us know if it works
ragopesa
Post by ragopesa » Wed Jun 21, 2023 12:58 am
Dear STKO,
Its now running. Thank you! I will keep you posted if it works for my model.
Sal
Salvador Ramos
Post by STKO Team » Thu Jun 22, 2023 10:25 am
