Analysis did not converge
sribeiro
Post by sribeiro » Sat Mar 25, 2023 12:26 pm
Hi everyone!
I was preparing a fiber section model and for that I was using as a reference the video https://www.youtube.com/watch?v=0lLeIZpLwlQ&t=34s
However, when I run my model, the .exe window says it does not converge.
Can someone help me find error?
bridge deck.scd.zip
(106.27 KiB) Downloaded 182 times
exe. window.png (455.36 KiB) Viewed 2119 times
Re: Analysis did not converge
Post by STKO Team » Tue Mar 28, 2023 7:55 am
Here's a fixed file:
bridge deck.zip
(106.63 KiB) Downloaded 164 times
It was singular from the beginning because you forgot to input -GJ (if in 3D you leave it as 0, your beam will be singular in torsion)
Now it will run for some steps and then it will stop converging because parts of your beam are crushing (and you did not put any steel in there):
sribeiro
Post by sribeiro » Tue Mar 28, 2023 11:27 am
Thank you very much!
Yes I didn't put any steel because the idea is to create an homogenised section (steel into concrete) for an easier analyses.
Do you think that will bring problems to the model and its results?
Post by STKO Team » Wed Apr 05, 2023 7:37 am
You can do it. But you will have to define a uniaxial material that contains both concrete and steel accounting for their volume fractions. You can use the parallel uniaxial material for this
