3D modelling of a pile in soil
chill
Post by chill » Wed Mar 29, 2023 3:31 pm
Hi I am trying to model a pile as 3D in a Drucker Prager soil (model attached), but I am having convergence issues (the model is not partitioned in the form sent, but that is not the issue, its within the analysis itself as it runs the first 2/3 stages when I partition it) and connot see what I have done wrong, would you be able to help please?
Thanks.
forum_3D_model.zip
(926.91 KiB) Downloaded 330 times
Re: 3D modelling of a pile in soil
Post by STKO Team » Thu Apr 13, 2023 7:55 am
Here's a working file:
3D_Model.zip
(890.06 KiB) Downloaded 322 times
You are using the "From Local Axes" option in contact, but you didn't assign any local axes to the interaction. Therefore, they will have their default one, with Normal = global Z (0,0,1):
In this way, the contact is not working fine, and you experience penetration of pile into soil:
Instead you need a Cylindrical local axes, with center at the center of the pile, so that the Normal vector will be radial (from master beam to slave soil):
In this way it works fine:
no compenetration.png (192.77 KiB) Viewed 3352 times
