Hi STKO team,
I m Arda. I m trying to learn this program for my thesis. I made model but I get errors mostly its because of gravity analysis I will add my model and SS of my errors. Can you help me. I m stuck at same place for a long time
Analysis did not converge
Ekrem Arda
- Screenshot 2023-03-11 122157.png (136.14 KiB) Viewed 1043 times
- Screenshot 2023-03-11 122135.png (148.79 KiB) Viewed 1043 times
- Model.rar
- (120.08 KiB) Downloaded 134 times
Re: Analysis did not converge
Double-check your beam elements.
There's something wrong:
- In the section aggregator for beams, you used the concrete material for Vy and Vz... are you sure? You should use a proper shearforce-sheardeformation, not a compression-only stress-strain law... as you did for the columns.
- Then you defined hinges at the beam-ends, but you assigned a material in only 1 DOF. It will be singular for all other 5 DOFs.
