The non-convergence of gravity analysis in two-dimensional tunnel modelis
[email protected]
Post by [email protected] » Thu Mar 09, 2023 2:33 pm
Dear stko
I have built a model of shield tunnel in liquefied soil layer. It does not converge in the first step of gravity analysis. I do not know where the problem is. The following is an introduction to the model
1. First of all, I choose binding constraint for the contact between tunnel and soil: equalDOF (X, Y direction)
2. The left and right boundaries of the soil layer are also bound in the way of equalDOF, (X direction)
3. Fix at the bottom of soil layer (X and Y directions)
4. The degree of freedom of pore pressure at the top of soil layer is fixed
Can you help me?
My gravity analysis cannot converge. I will attach my model below. Can you help me modify it?
zou.zip
(191.02 KiB) Downloaded 157 times
Re: The non-convergence of gravity analysis in two-dimensional tunnel modelis
Post by STKO Team » Fri Mar 10, 2023 8:33 am
UP elements cannot be analyzed in static analyses due to how the pore pressure DOF is implemented.
Therefore, if you have to run a "static" analysis, you must do it with a Transient analysis and a large time step so that you don't have inertia effects
[email protected]
Post by [email protected] » Fri Mar 10, 2023 11:44 am
Thank you stko I have modified my model,
but after the gravity analysis (elastic phase), I open the post-processing module and cannot display my post-processing. What is the reason?
(The post-processing of other models can be displayed normally when I open them)
page 1 is my model post-processing results
Here is my modified model
zou (2).zip
(191.09 KiB) Downloaded 154 times
[email protected]
Post by [email protected] » Fri Mar 10, 2023 12:12 pm
Dear stko
Im sorry
please download this model
The above model was sent incorrectly
zou (2).rar
(1.86 MiB) Downloaded 161 times
Post by STKO Team » Mon Mar 13, 2023 10:38 am
the top layer of soil is detached from the other one. It is falling down.
Select the 2 soil layer, merge them using the SewFaces command, and re-mesh.
The analysis should run after that
[email protected]
Post by [email protected] » Tue Mar 14, 2023 9:28 am
Thank you very much! i will try again!
and i want to ask a question,
In the phase of gravity elasticity analysis, I used a long analysis step(5step 5000totally time)
In the gravity plastic analysis stage,If I still use the analysis step size of (5 steps, a total time of 5000s), the analysis cannot converge, so I use the analysis step size of (40 steps, a total time of 2s) to calculate the convergence, is this correct?
Post by STKO Team » Wed Mar 15, 2023 8:27 am
It should be fine. Just record the acceleration and check if they are small enough
[email protected]
Post by [email protected] » Mon Mar 20, 2023 12:53 pm
ok,that is small enough
and i have an another question
if I want to extract the shear strain and shear stress of the soil element in the post processing. In the two-dimensional XY model, what I should extract?is the Gaussian point ε 12 and σ 12?
Post by STKO Team » Tue Mar 21, 2023 8:51 am
yes
