I have a problem with the analysis: I have chosen a parallel displacement control which requires a "point control" set by "selection set". I have identified as selection set the midspan bottom point and I input it in the analysis (as I have already done for similar case study) but I still have a final error that reports I haven't input the selection set.
I attached the model.
Thanks in advance for your help.
Regard
Selection set not recognized
AntoMarinelli
- 60.zip
- (1.13 MiB) Downloaded 261 times
Re: Selection set not recognized
The error comes from the first analysis (not the second).
The first analysis is set as a disp control without a selection set. I think you need a load control there
ValentinaSB
Hi AntoMarinelli,
it gives you the error due to your first analysis (prestress). You also used a displacement control and didn't insert the selection set. If I change to load control it runs. Best,
Valentina
Valentina
AntoMarinelli
Thank you all!
Antonella
Antonella
