Error of MPCO recorder in linux
When I used linux supercomputer system to calculate, the command model ran normally when I deleted mpco record. When I joined mpco, I encountered a new problem, I spent a week, but finally failed. Could you give me some advice?
The links to the opensees and methods I compiled are as follows:
https://github.com/MassimoPetracca/OpenSees
https://opensees.github.io/OpenSeesDocu ... build.html
Best wishes:
Best wishes:
- 20230223.png (116.46 KiB) Viewed 4021 times
- cont2.zip
- (2.8 MiB) Downloaded 225 times
Re: Error of MPCO recorder in linux
The STKO_VAR_process_id is automatically defined by STKO in the main.tcl file.
If you just copy-pasted that piece of code inside a file which don't declare that variable you have that error.
Just put this lines at the very beginning of your tcl file:
# The current process id (from 0 to NP-1)
set STKO_VAR_process_id [getPID]
Dear STKO Team:
I changed it according to the suggestion, but it still can't run. I used STKO to generate the code, but I don't know where the problem is. Can it run on your liux system (sbatch sub.sh), I have seen Massimo Petracca .PHD running STKO code on designsafe in linux, can you help me to see what is the problem? I have attached the code.
https://www.designsafe-ci.org/rw/worksp ... Simulation
Best wishes:
Best wishes:
- cont20230224.zip
- (2.8 MiB) Downloaded 241 times
- 20230224.png (85.97 KiB) Viewed 4004 times
Did you use CMake to compile it?
It's because you compiled OpenSees with CMake without the MPCORecorder.
To compile OpenSees with the MPCORecorder (and also with the DRM class), you need to install the HDF5 library (version 1.12.0) in a location that CMake can find.
Dear STKO Team:
When compiling the program code, I used Cmake, is there any other reason? I asked my colleague to follow the tutorial to compile, but it's the same problem, when I delete the mpco record, the program runs normally, but when I join, I can't record the result normally. Can you give me some advice?
Best wishes:
Best wishes:
- 20230225.png (30.11 KiB) Viewed 3988 times
If HDF5 1.12.0 is not installed in a directory that can be found automatically by CMake, you can help CMake find it by specifying the HDF5_ROOT variable as the root of your HDF5 installation.
For example in Windows it is: So I would use this:
cmake .. -DHDF5_ROOT="C:/Program Files/HDF_Group/HDF5/1.12.0"
As for HDF5, we still have problems after installing HDF5, cmake found HDF5, we studied the source code. In the source code, it defined HDF5 as if def _HDF5, and then executed mpco, but we checked the hdf5 compilation file under linux. There is no definition of marco _HDF5 in it. Then we check the official website file of hdf5 and find that it exists in the shared library of hdf5.lib in windows version. Now the main problem is that we can't find the definition of _HDF5. We tried 1.12.0 and the latest 1.14.0 hdf5, but we couldn't find the definition.Forum You provided the definition of HDF5 for windows. Can you demonstrate the definition of HDF5 for linux?,For example in Linux
- 20230205-3.png (19.09 KiB) Viewed 3961 times
- 20230205-2.png (7.46 KiB) Viewed 3961 times
- 20230205-1.png (4.48 KiB) Viewed 3961 times
The preprocessor macro _HDF5 is not in HDF5 itself, it is a macro required by OpenSees, so you should defined it in Cmakelist.As for HDF5, we still have problems after installing HDF5, cmake found HDF5, we studied the source code. In the source code, it defined HDF5 as if def _HDF5, and then executed mpco, but we checked the hdf5 compilation file under linux. There is no definition of marco _HDF5 in it
You are right, the CMakeList.txt contains an error.
It only defined the _H5DRM macro (used for the DRM object).
It should also define the _HDF5 macro
Try this and let us know.
When using Linux system to Solve by OpenSeesMP, the model ran normally, but when using the site stress balance ,plastic analysis, I encountered a new problem. When the material changed from elastic to plastic after gravity balance, the linux system could not solve, the program is interrupted, but Widows ran normally . have downloaded the folder versions of Widows and Linux last time, can you help me to see it?
Best wishes:
Rujiang Pan
Best wishes:
Rujiang Pan
- linuxx.png (84.73 KiB) Viewed 3872 times
- winds.png (61.49 KiB) Viewed 3872 times
- windows.zip
- (266.78 KiB) Downloaded 228 times
- linux.zip
- (260.94 KiB) Downloaded 216 times
- Did you manage to compile using the _HDF5 macro?
Does it crash? or is it just hanging? or not converging?the linux system could not solve, the program is interrupted
Are you sure the Windows and Linux version are the same? I mean, you compiled them from the same source code?have downloaded the folder versions of Widows and Linux last time, can you help me to see it?
