How to build Plate fiber for steel joint
Dear stko team
I am modeling a joint for steel frame,but there has some mistakes in the model.the error is “materials must be nD”.I want to know what`s wrong with the model.
Here I attach the model.
However,this model did not work.i was wondering which material I can use?what should i do to correct is?
Thanks
Thanks
- JOINT.7z
- (102.77 KiB) Downloaded 188 times
Re: How to build Plate fiber for steel joint
There are many mistakes here:
- The geometries are all separated. This will result in a singular stiffness matrix. I made a single geometry by selecting them all and using the "Merge" command.
- You cannot use a PlaneStressRebar Material. It's a material used to represent linear steel rebars smeared in a 2D plane stress model of RC shear walls. In your case, you need a full 3D Material. I used a J2 (Von Mises)
- The element for the surface geometry Must be a Shell, not a quad3D, which is for 2D analyses
- You cannot fix and imposed a non-zero displacement on the same nodes. I split the Fixities in such a way that you don't have the Displacement Fixed at the Imposed-Displacement DOFs.
Dear STKO team
Thank you for your responses
1.Follow your advices,I modeling the model but it did not work,the error is “invalid type of element or number of nodes?”where is the mistakes? I attachede the model.
2.I also want to know platefiber how to fiber section,what can I do if wants to mesh type by quadrilateral?
- joint-1.7z
- (50.96 KiB) Downloaded 181 times
- 1.png (19.86 KiB) Viewed 3889 times
ValentinaSB
Hi jingji10,
There was a problem that you did not use a structured mesh for your shell.ASDShellQ4 element. Now it is working.
Give a look at the description of the element you are using.
https://opensees.github.io/OpenSeesDocu ... ellQ4.html
I would also advise you to watch the webinar series "Get Started in OpenSees with STKO" https://asdeasoft.net/?stkowebinars-for-opensees. It will be helpful for you to be more confident with your modeling.
- joint-1.rar
- (53.99 KiB) Downloaded 191 times
Hi ValentinaSB
Thank you for your reply.
ValentinaSB
You are welcome!
Dear
I was use structured mesh for my shell.ASDShellQ4 element.but it also have some errors .maybe I make mesh control is wrong. where is the mistakes please tell? thank you !
- 1111.png (92.38 KiB) Viewed 3776 times
- joint-10(1).7z
- (110.62 KiB) Downloaded 253 times
ValentinaSB
The problem was that your geometry is not with 4 nodes, so even if you used mesh controls it could not generate the structured mesh. Look how I corrected your geometry, it would be more clear what I mean.
Notice that I have changed solver to UmfPack SOE.
Valentina
Valentina
- joint-10_corrected.rar
- (153.87 KiB) Downloaded 187 times
Dear Valentina
I modified the model as you said, but this error is displayed when calculating, please help see where is the problem?
- 1.7z
- (134.21 KiB) Downloaded 185 times
You have geometries that cannot be meshed with 4 node quads:
So I changed everything to a triangular mesh with a triangular shell element.
But please, double check your model because the boundary conditions are really strange.
- 1.zip
- (265.43 KiB) Downloaded 183 times
