Frame load high span ratio
zhangs
Post by zhangs » Thu Nov 24, 2022 8:12 am
I analyzed the concrete frame supported by the corner brace. When I analyzed the frame with the same height and different span, I found that his displacement load curve was not very different. I felt that it was a matter of self-weight, and I added a certain load but the difference was not obvious
KF(4 6 8)- 10.rar
(458.75 KiB) Downloaded 190 times
jpg.zip
(43.55 KiB) Downloaded 166 times
have a pattern
Re: Frame load high span ratio
Post by STKO Team » Thu Nov 24, 2022 8:54 am
The gravity load is not added to the loadPattern
zhangs
Post by zhangs » Thu Nov 24, 2022 9:17 am
I reloaded it and there's not much difference
纯框架 (4 6 8 ).rar
(462.73 KiB) Downloaded 172 times
have a pattern
Post by STKO Team » Mon Nov 28, 2022 7:50 am
I don't understand what you are trying to compare. Two of them have no braces. They are not the same model.
However, probably changing only the span is not going to influence a lot the shear strength given by the same 2 columns
