Vinyl plank has become one of the most popular choices for floor surfaces these days. Available in many physical forms, it's easy to install and maintain and can resist water very well.
This material can work with any aesthetic, thanks to a wide range of textures, patterns, and colors. These options allow vinyl plank flooring to match any decor and color scheme.
Another big plus is how easy it's to keep these floors clean. They don't require hours after hours of manual scrubbing on our knees. And unlike carpets, you don't need to hire professional services to steam them once in a while.
That said, you still need some special care when it comes to vinyl plank floors. For starters, not every cleaner is compatible with this floor type. So, what is the best choice we have?
Cleaners For Vinyl Plank Floors
From the get-go, vinyl is designed for easier cleaning and maintenance. It doesn't need expensive cleaning solutions to stay clean and fresh and keep its bright luster.
There are plenty of normal spray cleaners that can work great on vinyl plank flooring. If they come with a spray-on bottle, you can just spray some of it on the floor and wipe away stains.
These off-the-shelf choices offer the most convenience when you have a busy schedule. Just remember to read the label carefully so you don't end up with a cleaner not compatible with (or even harmful to) vinyl plank floors.
We recommend natural floor cleaners. Avoid products that have ammonia, waxes, or strong detergents. These ingredients are toxic and can create severe damage to the finish of your vinyl plank flooring.
Never reuse the cleaners for hardwood floors as they usually contain waxes and oils, which can dull the vinyl finish and ruin it.
Aside from commercial products, you can also make your own homemade cleaners from household supplies. A lot of people have seen great results with apple cider vinegar, which is mixed with warm water and then mopped or sprayed on the floor.
Read More:
A Comprehensive Guide to Getting the Best Mop for Vinyl plank Floors
Best Mop for Vinyl Floors: TOP Options for Long-Lasting Flooring
How To Clean Vinyl Plank Floors
In addition to getting the right cleaners, you should have a firm grasp of vinyl plank's other maintenance requirements.
Although they're generally simple and easy to follow, it'd be better to use the best practices and tips so your floors can be as clean and shiny as their first days.
Begin a cleaning session by sweeping them thoroughly with a dust mop or broom. Gently get all the dust particles away without scratching the finish.
Whether it's a commercial cleaner or a solution of water and apple cider vinegar, ready the cleaning agent of your choice. Use a wet mop to thoroughly wash the floor. Check out the Best mop for Vinyl floors.
If you encounter acidic spills like vinegar, ketchup, or orange juice, add some baking soda into a soft cloth. Dampen it and rub the cloth on the stained area. The sodium bicarbonate agent in this will neutralize the acid without taking a toll on your floor.
Avoid steel wool or scouring pads as these materials can scratch vinyl plank's finish and reduce its shine.
If you aren’t familiar with those cleaning tools, learn more about them at Best Mop for Vinyl Floors: Buying Guide and TOP Suggestions.
Conclusion
As this is a highly water-resistant and durable material, vinyl plank flooring can last a lifetime with proper care. Remember important recommendations, such as the Best mop for Vinyl plank floors, and you won't have to repair or replace your flooring anytime soon.
