After Running Analysis Some Error Show Below
LHIEOANRT
Post by LHIEOANRT » Fri Oct 21, 2022 7:56 am
I creat a steel frame model and try to run analysis,but after "Run Analysis" the error show below appear in dos.
steel frame.zip
(111.93 KiB) Downloaded 315 times
ERROR OF STKO.png (27.32 KiB) Viewed 4626 times
Re: After Running Analysis Some Error Show Below
Post by STKO Team » Mon Oct 24, 2022 9:30 am
It's because you are using OpenSeesMP (for parallel analysis) but you forgot to partition your mesh
LHIEOANRT
Post by LHIEOANRT » Wed Oct 26, 2022 1:54 am
Thank you so much.
Post by STKO Team » Thu Oct 27, 2022 7:41 am
