MESH ERROR SOIL DOMAIN
Re: MESH ERROR SOIL DOMAIN
Dear STKO team
Now I modeled the entire proyect, but I had some troubles.
1. First mistake the model didn´t get to run the vertical analysis of strecture and the mistake was the following it´s: ctestNormDispIncr::test() -failed to converge
I don´t know why have this problem and the model couldn´t converge.
2. I´ve changed the time step type to Adaptative time Step and I get to run the vertical analysis of structure but I had a warnings that sais: END OF INTEGRATOR :: debugInfo= 1 2 -1 -1 -1 2 0 0 21.58 1e+12
Finally the model got to finish the vertical analysis of structure
3. When the model star the transient analysis this warning appear: MCP1419::unload from plastic.
The model take so long time just for get to run 4.94% of the transient analysis (about 1 hour and 35 minutes)
Please your help
Best regards
I've attached the mistake´s images
allano89
Please your help
Best regards
allano89
- ERROR CONVERGENCIA 3.png (42.77 KiB) Viewed 5184 times
- ERROR CONVERGENCIA 2.png (66.3 KiB) Viewed 5184 times
- ERROR CONVERGENCIA 1.png (54.17 KiB) Viewed 5184 times
- MODELO COMPLETO.png (127.3 KiB) Viewed 5184 times
Those messages refer to warnings or errors in the Multiaxial Cyclic Plasticity. First make sure your model works with Elastic material (instead of the MCP). If it works without problems, use the MCP and double check (with the opensees manual) if your input parameters are correct.
Thanks a lot
Precisely that was the problem. You are the best thanks a lot.
Maybe do you have some references/researches about how works Multiaxial cyclic plasticity?
Best regards
allano89
Best regards
allano89
this is what I found in the source code:
| (1) This is implementation of MultiaxialCyclicPlasticity for clays |
+ Model References: +
| Borja R.I, Amies, A.P. Multiaxial Cyclic Plasticity Model for |
| Clays, ASCE J. Geotech. Eng. Vol 120, No 6, 1051-1070 |
+ Montans F.J, Borja R.I. Implicit J2-bounding Surface Plasticity +
| using Prager's translation rule. Int. J. Numer. Meth. Engng. |
| 55:1129-1166, 2002 |
+ Code References: +
| Ignacio Romero and Adrian Rodriguez Marek, Brick element model with |
| a Multiaxial Cyclic Plasticity Model, in GEOFEAP, UC Berkeley |
+ (2) Questions regarding this code should be directed to Gang Wang +
| (3) Documentation could be found at |
| www.ce.berkeley.edu/~wang/papers/MultiaxialCyclicPlasticity.pdf |
