Question about running multiple motions by a separate tcl script
youngkyu
- Location: 2559, Gyeongsang-daero, Sangju-si, Gyeongsangbuk-do, Korea
I have a question about running multiple ground motions in parallel using OpenSeesMP.
I saw the post regarding this same question,
however, I want to modify the tcl file that runs 3 ground motions in parallel which is available from DesignSafe example (Multiple_Motions_DesignSafe_OpenSeesMP_Example.zip) that I attached below.
Multiple_Motion_YC.zip file is what I tried.
I used the customCommand to put the tcl script for dashpot, force application, and dynamic analysis step,
and made a separate Parallel_Motions.tcl to run 8 ground motions simultaneously by OpenSeesMP.
But, it did not work as the DesignSafe example.
FYI,
If you run the below code in the command line interface for the DesignSafe example,
C:\OpenSees-Solvers\openseesmp.bat .\parallel_motion.tcl 3
you will see that 3 ground motions run simultaneously, which produces 3 out files corresponding to each ground motion.
Best Regards,
Youngkyu
FYI,
Best Regards,
Youngkyu
Re: Question about running multiple motions by a separate tcl script
sorry there is no file attached
youngkyu
Thanks for letting me know that.
(I am sure that I added two attachments when initiating this post.)
I added them again.
Please let me know if the same thing happens again.
Also, please use Parallel_Motions.zip for Parallel_Motions.tcl file that I just updated
when testing Multiple_Motions_DesignSafe_OpenSeesMP_Example.zip file.
Youngkyu
I added them again.
Youngkyu
- Parallel_Motions.zip
- (709 Bytes) Downloaded 173 times
- Multiple_Motion_YC.zip
- (1.89 MiB) Downloaded 195 times
- Multiple_Motions_DesignSafe_OpenSeesMP_Example.zip
- (15.13 MiB) Downloaded 196 times
Why are you using this if-statement?
In this way, you will add the dashpot only on process=0! Here I also put an MPCORecorder whose name is parametrized with the MotionID tcl variable defined like this:
if {[expr $countP % $np] == $pid} {
set gMotionName [string range $gMotion 0 end-4]
set MotionID [string range $gMotion 14 end-4]
youngkyu
Thanks for your quick response.
To put a single dashpot and a single nodal force for the earthquake load at the left corner of the model bottom,
I constrained x-dof of all the nodes at the model bottom by considering the area of the model bottom.
I followed the idea that uses a single dashpot and a single node for earthquake load from
https://opensees.berkeley.edu/wiki/inde ... s_of_Slope
So, to achieve this, if I do not specify the processor id under opensees-mp,
I got an error that the processors other than 0 do not have the "node tag 16" that exists in the equalDOF command.
You can see what happens if you remove that if statement.
Youngkyu
Youngkyu
youngkyu
When running your file that includes the mpco_recoder$MotionID in the command line interface (submitting the "Parallel_Motions.tcl),
the first ground motion file only runs even though the Parallel_Motions.tcl script creates 8 different names of the output file.
i.e., as attached below, all mpco and output files have the same amount of storage, which tells me that the mpco_recorders and .out files for other 7 motions were not created.
Also, I opened the 8 .out files that are all same.
After fixing this issue, I would like to ask one more question.
I would like to apply multiple motions in parallel to a slope model with multiple partitions.
For instance,
let's say that I have 2 ground motions and a single slope model.
1. I want to assign 8 partition to a single slope model. (i.e., 8 processors specified for the slope model)
2. I want to enter 2 ground motion simultaneously in the the slope model.
Motion 1: 8 processors needed
Motion 2: 8 processors needed
In total, 8 x 2 = 16 processors needed.
This is my final goal for this question.
Youngkyu
For instance,
Youngkyu
- Parallel_Motions_YC.PNG (56.54 KiB) Viewed 4034 times
youngkyu
As attached SCD file, I resolved the problem that only saves one single ground motion for *.out file.
You can find that I used the "analyze scheme" for dynamic analysis used in "Multiple_Motions_DesignSafe_OpenSeesMP_Example,zip" that I attached in the above post.
(i.e., you can see the command lines from #150 to #202 in the number 17 of the analysis tree)
This gives me the *.out file for the individual ground motion that I wanted.
Now, the next thing that I want to achieve is that
I want to assign multiple partitions to the slope model supported by OpenSeesMP.
For instance, I want to divide the slope model into 4 partitions (i.e., 4 processors given to the slope model) and then
run the 8 ground motions in parallel.
Thus, the entire analyses uses 4 x 8 = 32 processors at the same time.
Best Regards,
Youngkyu
Best Regards,
Youngkyu
- Slope_OpenSeesSP_MultipleMotions.zip
- (670.01 KiB) Downloaded 218 times
Using OpenSeesMP processors for both partitioning and parametrization is quite complex.
It is easier if you create an external procedure that does that, something like this:
- in the STKO file, use a customCommand to create a uniformExcitation which takes the timeSeries data from the input arguments ($argv)
- externally call the OpenSeesMP multiple times, passing a parameter for the timeSeries to use
youngkyu
Thanks for your advice and it would be appreciated if you describe what you suggested in more details.
I am willing to do change something to achieve this goal.
Youngkyu
Youngkyu
Ok but before doing that,
I would suggest you change the way you add the compliant base.
Instead of manually adding the LK dashpot using zero-length elements you can use the new ASDAbsorbingBoundaryElement (2D or 3D).
Because now we need to partition your model using OpenSeesMP, and it will be a mess if you add manually the dashpots because you need to know which subdomain will contain the dashpot.
Once you convert your model to use the ASDAbsorbingBoundaryElement, I will show you how to do the rest.
Here you can find the relevant documentation:
https://opensees.github.io/OpenSeesDocu ... ndary.html
While on our webinar page (https://asdeasoft.net/?stkowebinars-for-opensees) you can view the webinar #25 to learn how to use it in STKO
