DamageTC3D in RC shear wall
[email protected]
Post by [email protected] » Sat Mar 12, 2022 1:35 am
I'm the first to attach the STKO software, before I study ABAQUS. I followed the teaching video about RC shear wall in Online Course Day 1 (https://asdeasoft.net/?university-courses) to establish the model. But the scd model files I established and downloaded on the webpage could not run successfully. If the DamageTC3D is wrong? I don't know the reason, I want to run an example model and learn how to establish.
The scd models files and running question picture are provided in attachment. The scd model file named by “wall-study-220310” is what I established, and the scd model file named by “wall-teach-220310” is download in the webpage.
Could you tell me the reason and how to solve the question? Thank you.
220312.zip
(481.51 KiB) Downloaded 198 times
Re: DamageTC3D in RC shear wall
Post by STKO Team » Mon Mar 14, 2022 3:34 pm
It's because it was done with a very old version of STKO, where we did not have an adaptive time step.
You can simply set the duration and number of increments (and the adaptive time step) directly in the analysis command, and get rid of the last custom command.
[email protected]
Post by [email protected] » Tue Mar 15, 2022 2:57 am
Thank you for your reply. But there are errors for the property.Image
If shoul I change the Plugin Library "pdm" in Opensees install file?Image
[email protected]
Post by [email protected] » Tue Mar 15, 2022 8:06 am
The concrete 1D property and 3D property were designed as Image and Image, but the error is as Image.
At the same time, there are other running errorsImage, I don't know how to solve it.
Look forward to your reply.
Post by STKO Team » Tue Mar 15, 2022 2:41 pm
Don't worry, those are not errors!
They are just messages to make sure that the plugin library (pdm) is correctly un-loaded (destroying library handle) and to count the number of materials used in the model.
[email protected]
Post by [email protected] » Wed Mar 16, 2022 1:00 am
Okay. However, the program stopped running. What should I do to finish the grogram and get the results?
Post by STKO Team » Wed Mar 16, 2022 9:08 am
The program did not stop running with an error. It's just finished correctly (ANALYSIS SUCCESFULLY FINISHED is a message that says that the analysis is done.)
Now, in that folder you should find a file with the *.MPCO extension. (if you used the MPCO Recorder command).
In the STKO post processor you simply need to load that file (Load DataBase command)
[email protected]
Post by [email protected] » Wed Mar 16, 2022 1:43 pm
Sorry, maybe I'm not being clear. I do not get the results. Because, after I submit the model file, the progress ran a few senconds and then teminited. And the .mpco file is only 1.75 MBImage, which is far samller than the size of .mpco file on the teaching vedioImage.
I thinck that there is some wrong. Could you try to run the .scd file named by "wall-teach-220316" in the attachment
220316.zip
(1.04 MiB) Downloaded 194 times
? And you can find where the wrong is. Thank you.
Post by STKO Team » Wed Mar 16, 2022 2:29 pm
It's because in the horizontal analysis you set a duration = 0.
In this way, it was skipped.
Put 1 instead.
[email protected]
Post by [email protected] » Fri Mar 18, 2022 3:02 am
Thank you. The model is successful.
I hope the scd model file should be update,. It can be helpful for new leaner.
The course is the online course day 1: RC shear wall.https://asdeasoft.net/?university-courses
The scd modle is in the attachment
wall-teach-220318.zip
(177.88 KiB) Downloaded 187 times
The SKTO is an excelent FE software. I hope more and moer people can use it and the software will be better.
