Time History Analysis
akshaysomkuwar123
Re: Time History Analysis
Post by akshaysomkuwar123 » Wed Dec 15, 2021 11:15 am
Thank you very much for the help. I will try to work out with the code you have provided.
akshaysomkuwar123
Post by akshaysomkuwar123 » Thu Jan 06, 2022 12:16 am
This forum has been one stop solution for my OpenSees problem. I am very thankful for your kind suggestions.
I would like to know is there any way to find damping force in a member. I know OpenSees provide damping force at nodes but if one would like to extract damping force in an element is there a way to do that?
Thank you very much
Post by STKO Team » Thu Jan 13, 2022 6:31 pm
some elements support the "RayleighForces" output.
However not all of them, and also they do not clearly explain what the components are.
ankurjain1992
Post by ankurjain1992 » Mon Feb 21, 2022 8:23 am
Can we do Linear Time History Analysis using ForceBeamColumn Elements with Concrete02 and Steel02 uniaxial materials.?
What differ Linear and Non-linear Time History analysis in OpenSees STKO ?
Is Elastic section and fibre section makes the difference ???
Clarabella
Post by Clarabella » Mon Feb 21, 2022 11:57 am
No this would be a Nonlinear Analysis
Look into the published literature, it does not depend on the program.
Elastic section is elastic, fiber section is subdivided in fibers
ankurjain1992
Post by ankurjain1992 » Mon Feb 21, 2022 12:05 pm
Didn't found anything in the literature. In other software like ETAB and SAP2000, direct option is there to select Linear or Non-linear analysis. But in STKO, I don't find this option. Actually I need to compare the results of the Linear and Non-Linear Time history analysis. So I need to do both.
So any way that I can do both Linear and Non-linear on a structure?
Post by STKO Team » Mon Feb 21, 2022 2:39 pm
Linear analysis:
Use elastic materials
Use Linear algorithm
Nonlinear analysis:
Use any kind of material
Use Newton (or other) algorithms
ankurjain1992
Post by ankurjain1992 » Mon Feb 21, 2022 2:59 pm
Ok thanks you so much.
Dongzheng
Post by Dongzheng » Wed Feb 04, 2026 2:56 pm
Could you please tell me how your dome-shaped TCL model was constructed? Did you import OpenSees through other software?
