contact parameters
contact parameters
Dear STKO team
How can I determine the parameters: Kn, Kt, mu when I use the zerolengthcontactASDsimplex?
What is the meaning of these parameters?
Is there any relevant paper reference?
Thank you for replying.
Horace Horsecollar
Re: contact parameters
Dear Wngyun,
Kn: Normal stiffness. It is the Elasticity modulus in the normal direction to the contact element. You can assume 10~100 times the smallest value of E of the elements in contact.
Kt: Shear stiffness modulus. It is the Elasticity modulus in the tangential direction to the contact element. You can assume 10~100 times the smallest value of G of the elements in contact.
mu: friction
Regards
mu: friction
Regards
Dear Horace Horsecollar
Tnank you
Why is the parameter determined in this way? Are there any references?You can assume 10~100 times the smallest value of E of the elements in contact.
Tnank you
There are several publications please check in the literature
When will you solve this problem? viewtopic.php?f=33&t=2175
I met the same problem.
Can you solve it as soon as possible?
Dear Wangyun,
we are going to answer that topic as soon as we can. We are really sorry for the delay, we kindly ask you to be patient for a few more days.
Thank you for understanding
Dear Francesca
Your staff referred me to that example, but I did, and now there's a problem, and no one's fixing it.
Please solve it as soon as possible.
Thank you very much
Thank you very much
We just gave an answer
