mpiexec.hydra.exe.stackdump
spater
Post by spater » Mon Jan 03, 2022 12:28 am
I have the same problem. Can you help me solve it?
viewtopic.php?f=20&t=1663&p=2150&hilit= ... dump#p2150
Re: mpiexec.hydra.exe.stackdump
Post by STKO Team » Mon Jan 03, 2022 3:09 pm
What operating system are you using?
What OpenSees version?
spater
Post by spater » Tue Jan 04, 2022 6:48 am
  • This is my computer properties
Screenshot 2022-01-04 144214.png (40.86 KiB) Viewed 7097 times
  • This is the OpenSees-solvers
Screenshot 2022-01-04 144411.png (36.71 KiB) Viewed 7097 times
    It works normally on other computers, but not on this one. Could you help me solve it? Thank you very much.
    Post by STKO Team » Tue Jan 04, 2022 9:31 am
    It should work on Windows 10.
    Make sure hydra_pmi_proxy.exe and mpiexec.hydra.exe (in C:\OpenSees-Solvers\bin) are allowed by the firewall.
    Make sure the antivirus is not blocking anything in C:\OpenSees-Solvers.
    If you are not sure, download again the OpenSees-Solver installer, disable the antivirus, and install it again
    spater
    Post by spater » Tue Jan 04, 2022 10:57 am
    You mean WIN10pro is unable to use?
    I shut down the firewall and antivirus on the WIN10pro, The same problem arises.
    Post by STKO Team » Tue Jan 04, 2022 4:56 pm
    I mean that it should work without any problem on Windows 10. We only had some known issues with Windows 7.
    Did you try to re-install OpenSees-Solvers while the antivirus is OFF?
    spater
    Post by spater » Wed Jan 05, 2022 12:47 am
    Yes I did. In fact, it worked fine the first time I used it on my workstation, but when I used it again a week later, I found this error.
    Post by STKO Team » Wed Jan 05, 2022 10:54 am
    Well this is strange, it means something happened during that week. probably some new software or some windows settings?
    mlaur96
    Post by mlaur96 » Thu Mar 14, 2024 1:55 pm
    Hi! Did you manage to solve the problem in Windows 7? I am having the same error but using window 7
    Post by STKO Team » Fri Mar 15, 2024 1:48 pm
    What is exactly your issue?
