How to consider the rotational mass in linear elastic static analysis?
pucho
Re: How to consider the rotational mass in linear elastic static analysis?
Post by pucho » Tue Dec 07, 2021 11:58 am
Thank you, Francesca!
Post by marafini.f » Thu Dec 09, 2021 8:07 am
You are welcome :)
pucho
Incorrect results with 3D elements using damaged-based model
Post by pucho » Fri Feb 10, 2023 1:04 am
Dear,
Thank you for your previous help.
I been successfully using the damaged-based model to characterize micro-models of masonry in plane stress conditions. However, now I need to model and adobe RVE using 3D elements with the damaged-based model. The analysis runs; however, the results are incorrect, and the post-process shows strange deformations and no damage. Please check my code.
Best regards,
Hernan
RVE_.zip
(569.26 KiB) Downloaded 390 times
Post by STKO Team » Fri Feb 10, 2023 3:21 pm
I think you sent an incomplete model. There is no analysis.
Please send the correct model
