Hello Dear STKO Team,
I am trying to model a simple cube element made of concrete (modeled with DamageTC3D material) subjected to compression by a concentrated force and I want to extract the stress-strain curve for this element. When I run the analysis, I get the attached message and, of course, there is no file created with the analysis. I will also attach the model. Please help.
All the best,
Alexander
Bad termination of one of your application processes
Alexander Bogdan
- Cube.7z
- (68.57 KiB) Downloaded 182 times
- Capture.JPG (111.62 KiB) Viewed 1902 times
Re: Bad termination of one of your application processes
You are partitioning in 4 parts a model that has too few elements.
Few other errors:
Few other errors:
- the controlled DOF should be 3 (Uz) not 5 (Ry)
- the controlled target displacement should be negative for compression
- in the monitor Y-axis you should use either the reaction forces in Z (you need a selection set with the bottom face) or the Pseudo-time (which in displacement control is the load multiplier, in this case you can use 1 as reference force, and lambda will be the total force), if you want to measure the vertical force
- since you fixed all DOFs at the bottom face, and the top face is restrained in a RigidLink, you need to refine your mesh to simulate a uniaxial test. With just 1 element along the height, your model results in a fully confined compression test.
- fix the rotations of the control node, otherwise the top face may rotate due to round-off errors
Alexander Bogdan
Thank you for the response.
you're welcome
