I am trying to model a masonry wall in STKO following the equivalent frame method. I have watched your webminar on the lumped plasticity modelling of RC frames.
To do so, the panels will be beam-column elements with two flexural hinges assigned at the top and bottom. Additionly, I want to add a shear-hinge at mid-height of the beam. I have some questions:
- How can I add this shear-hinge at the middle of the frame? I have seen this other related topic but it is not defined viewtopic.php?f=36&t=1778.
- Since it is not a RC frame, I need to use any fiber-section element different from the rectangularbeamsection. I have seen that I could use just the fiber element defyning the section of the wall. What do you suggest?
- I want to perform a nonlinear static analysis. During the application of horizontal loads, the acting axial load changes from the inital value consequent to the vertical dead loads. Also, due to the redistribution phenoma associatted with the progressing of non-linear response, further variations may occur. Hence, the value of the corresponding shear strength varies in each panel. I am not sure if this could be considered by performing any parametric analyses. I have seen that in your webminar you changed the values of the concrete but you performed different analyses, not updating the input parameters each step of the analysis. SO, I am not sure if this could be possible to do.
- I have seen in youtube that you have already modelled a building following this approach but it is not in any of the webminars...so i guess that you might have already studied this issue
Regards.
