Question about using PyMPC
youngkyu
- Location: 2559, Gyeongsang-daero, Sangju-si, Gyeongsangbuk-do, Korea
Dear support team members,
I found an issue with changing the value by using PyMPC.
If you run the python script within the attached .scd file, the value is not changed as described below.
If you look at the command in the line # 103 of the python script,
"doc.getAnalysisStep(13).XObject.getAttribute('duration').real = float(N[k]*0.01)", this does not change the value that I assigned as (N[k]*0.01)
It's weird because the same command for 'numIncr' worked changing the value in the line # 102 as you can see.
I guess that this might be a bug or error in this version of SKTO?
I hope that this issue will be resolved soon.
Youngkyu
Youngkyu
- PyMPC_Youngkyu.zip
- (162.51 KiB) Downloaded 311 times
Re: Question about using PyMPC
Dear youngkyu,
no bug there, just some notation that it's hard to find.
For a transient analysis the attribute duration is called "duration/transient":
So you need to substitute this in line 103 in your code:
If you encounter some other problem you can go in this folder on your computer
C:\Program Files\STKO\external_solvers\opensees
and explore how each X-Object is created.
Here is an example of the information you were looking for, which was found in the AnalysesCommand.py file:
Let us know if you need anything else.
doc.getAnalysisStep(13).XObject.getAttribute('duration/transient').real = float(N[k]*0.01)C:\Program Files\STKO\external_solvers\opensees
youngkyu
Thanks for the quick response. That worked well and I will keep in mind your example for my future application.
Youngkyu
Youngkyu
You are welcome!
youngkyu
Dear support team member,
Although I viewed PressureDependMultiYield.py script,
it is not straightforward to find the correct expression.
I tried to change the parameters of the models that are
rho, refShearModul, refBulkModul, frictionAng, refPress, PTAng, contrac, dilat1, dilat2, and e through PyPMC as above.
However, I could not change rho, refShearModul, refBulkModul, and refPress.
Could you help find what I missed from the script to access to the object ?
Youngkyu
Youngkyu
- Change_PDMY_Params.zip
- (148.79 KiB) Downloaded 308 times
Those parameters are all QuantityScalar, not reals.
when trying to change them you should call them as for the following example:
SoilP.XObject.getAttribute('refBulkModul').QuantityScalar.value = 10.0
Let me know if you need any more help.
youngkyu
Thanks for your quick response.
Actually, the lower case "quantityScalar.value" worked for the job.
Youngkyu
Youngkyu
Great! Sorry for the typo, but I am happy you managed!
Enjoy your modelling.
