When i run STKO Stop Working
damvelisa
Post by damvelisa » Mon Nov 30, 2020 11:36 am
When I launch the STKO on my laptop. the program stopped immediately
YZuCgLJ - Imgur.png (409.19 KiB) Viewed 3065 times
HC2020
Re: When i run STKO Stop Working
Post by HC2020 » Mon Nov 30, 2020 11:55 am
Dear Damvelisa,
First of all, nice background!
The problem could be that your graphics card doesn't support the minimum requirements of STKO. If you are using a laptop, your computer may come with two graphics cards: an integrated one (less powerful, meaning energy saving), and an Nvidia (or other which is more powerful). You should attempt to change the graphic card accessed when you open STKO by following one of these two procedures:
1. Right-click on the STKO icon and select Run with graphics processor -> High-performance NVIDIA processor (default).
2. Right-click on the desktop and run NVIDIA Control Panel -> Manage 3D settings -> ADD -> STKO.exe -> Add Selected Program -> Apply.
Finally, launch STKO. The issues should be fixed!
Note that method 1 is faster, but you will need to do it every time you want to run STKO. Method 2 is slower, but you will only have to do it once.
Let us know if this doesn't solve the problem.
damvelisa
Post by damvelisa » Mon Nov 30, 2020 1:02 pm
okay, i will try. thanks for your advice. :D
