My model utilizes the ASDConcrete3D material, I upgraded my OpenSees-Solver veision from 3.4.0 to 3.7.2 (both are compiled versions by Prof. Tarque).
However, after completing the calculation using version 3.7.2, when I try to open the post-processing file, I receive a prompt:
Cannot open output database "PATH/Earthquake Results.part-*.mpco"
Partition "PATH/Earthquake Results.part-*.mpco" is not valid (it will be skipped).Cannot open output database When I roll back to version 3.4.0, I could load MPCO files during the calculation process, but in that case I couldn't use ASDConcrete3D material for the calculation.
Do you have any solutions?
