Question about mesh and modeling in STKO
Jamildouier
Re: Question about mesh and modeling in STKO
Post by Jamildouier » Tue Apr 21, 2026 6:23 pm
Hello stko Team,
this is a kindly reminder.
Thank you for your support in advance
Post by STKO Team » Wed May 20, 2026 7:20 am
However, I have another question. I am working with the same model, with the only difference being that the plates must not come into contact with each other. I would still like to connect these plates without them touching (i.e., without a node-to-node connection).
In the eigenvalue analysis, the plates currently deform independently. I would like them to move and deform together instead.
I didn't get this point. You don't want them to be connected, but they should still move together?
Could you clarify?
Jamildouier
Post by Jamildouier » Tue May 26, 2026 7:33 pm
I want the parts to be connected to one another without directly touching—that is, based on the same principle as an Interaction.
However, when I connect them via an Interaction, they do not move together completely, but only partially.
Post by STKO Team » Thu May 28, 2026 9:12 am
You have overlapping constraints.
So you should use a fake analysis before the eigen to tell OpenSees NOT to use Transformation handler.
Check the attached model
Versuch_mittlere_Platte_1.zip
(304.2 KiB) Downloaded 13 times
