PML element in STKO
Re: PML element in STKO
Dear Stko Team ,
Thank you for your response,
I did not pay attention to the new updated as it was edited from the previous response.
As you mentionned earlier in your replay, that the implementation is quite stright forward for the PML. Can we do that for the 2D case . I guess this would help a lot to solve some 2D problems and quite easy to compare the implementation.
Thank you ,
Thank you ,
Hello STKO Team,
Is there any update on the posted issue for 2D case.
Thank you,
Thank you,
Dear user,
The implementation is almost done, we're doing some testing. It should be out by the end of the month
Thank you for your response, I am looking forward to it.
I want to kindly follow up to check whether the implementation is done.
Thank you ,
Thank you ,
