Dear STKO
I have been trying to follow Dr. Massimo's YouTube "New Element- Embedding Rebars into Solid Domains", at about the 44 min mark. I have also searched this forum for more help.
I am creating a prestressed beam, following exactly Dr. Massimo's procedure. The issue is I keep getting an error "WARNING: InitStressMaterial - could not find initStrain to within tol for material: 5 wanted sigInit: 0 using tStress: 0"
Is there an example file from that video that I can download, to see where my issue is?
Also, does this scripting procedure work if I am using OpenSeesMp?
Thank you so much.
PreciseLogic
Prestress script to increment applied prestress
PreciseLogic
Re: Prestress script to increment applied prestress
this is just a warning due to internal very strict tolerances they use in InitStressMaterial."WARNING: InitStressMaterial - could not find initStrain to within tol for material: 5 wanted sigInit: 0 using tStress: 0
For more info you should share your model
